Primatet
Jun 17, 2016Aspirant
Sudden network issues with a NASNetwork, Troubleshooting
I have a Synology NAS hooked up t my Netgear router. It has worked flawlessly up to now. I can access the nas via http://192.168.1.8:5000/index.cgi I can access any of the shares. The IP adress fo...
- Jul 16, 2016
Turns out it was the NAS was the source of error. Did a fabric reset that solved everything
TheEther
Jun 26, 2016Guru
I have a Synology NAS and have no problems accessing it from Windows and Mac.
It's strange that you can log into the Synology's web portal but yet you can't ping it. Have you checked that the firewall on the Synology isn't blocking anything?
Do you have jumbo frames enabled on the Synology? If so, turn it off. Netgear routers do not support jumbo frames.
Primatet
Jul 16, 2016Aspirant
