gotigers
May 03, 2021Aspirant
sudden R7000 slow wifi
Xfinity 1G service, i get 800-900Mbs. Netgear CM1000 v2 Modem. Until a week ago, any wireless device was getting 200-400mbs. The day after my hardware warranty went out, that stopped. Nice scam n...
- May 05, 2021
There is a newer version of the firmware version 1.0.11.116.
Also, the agreed upon stablest/fastest version is the 1.0.9.42 version.
With any changes tot he R7000 firmware, I recommend doing it over a hardwired connection and then doing a factory reset/clean install afterwards. By clean I mean don't use a backup configuration.
gotigers
May 04, 2021Aspirant
I've tried 2.4, 5 and smart connect
Firmware - V1.0.11.110_10.2.100
Iphone 11, Ipad gen 7, Ipad air gen 3, Roku stick, fire stick. All slow and buffering
May 05, 2021Guru - Experienced User
- gotigersMay 06, 2021Aspirant
I updated the firmware. That solved much of the issue but not all. Changing the 5Ghz to channel 48 (closest to 50 available) got the signal much stronger. The signal went from under 10Mbs to over 140Mbs while testing 4 wireless devices at the same time. Not bad. I will wait and test again tomorrow to make sure it was a perm fix. If it is still over 140 per device tomorrow, i will select the above post as a solution.
