Hiker_Bob's avatar
Aug 27, 2021
Suddenly my printer, iphones and smart TV's Won't Connectg
I've had my Model R7000 router since 2013 with no WiFi problems connecting multiple devices.  Suddenly today, my Printer, iPhones and Smart TV's won't connect to my router.  I've rebooted all devices...
  • Kitsap's avatar
    Kitsap
    Aug 27, 2021
    Give this a try:
    You have managed to manually turn off the Wi-Fi radios. Neither firmware updates or reset to firmware default settings or cycling the power will change the state of the on/off switch. Once turned off, it stays off until manually turned back on.
    When looking from the front of the router, the last two leds on the far right are a combination indicator/switch. The second one in is the Wi-Fi radio on/off switch. Press and hold for two seconds then release. Your Wi-Fi radios should come back on.
