Silverwolf75
Apr 13, 2021Initiate
Suddenly Very Slow Speeds on my Nighthawk X4S AC2600 R7800 Router
hi Same as another thread i have seen. Wired connections sudddenly only giving me 50-70 Mbps on speedtest. sued to get 250 easily Runnign speedtest from build in speedtes in router still give...
Apr 13, 2021Guru - Experienced User
Did you try a factory reset and reinstall?
What modem is it connected to?
- Silverwolf75Apr 21, 2021Initiate
Suddenly issue solved itself
