Mike_L299
Jul 08, 2021Follower
Suggested Replacement for Verizon Fios Router
Looking for a suggestion for a good replacement for my FIOS router. Would I need a Moca adapter with your suggestion. Looking for about $200. Thanks
Jul 08, 2021Guru - Experienced User
I don't know of any Netgear devices that currently support moca.
Also, you need to make sure verizon will have an ONT at your locatio of if the gateway is needed or not
