mouthman
Jun 17, 2021Aspirant
suggestions for new firmware R8000P
mouthman
On the r8000p there should be a way to block people out of your network. Now if you block a person (on mac -level) unknown to you, they have no internet, but can still snoop around in your network. That is how a neighberhood-kid was able to obtain my registration-code and thus was able to constantly change my wifi-password, making it impossible for my daughter to follow her schooling via the internet. I'm having my router swapped (thanks Amazone) because of course he has this code written down somewhere.
michaelkenward
Jun 18, 2021Guru - Experienced User
Really? How?
How can someone get into the controls of your router without knowing the router's login password?
- mouthmanJul 05, 2021Aspirant
There seem to be hacker who can get past these passwords I've changed these passwords several times.... he gets hold of it every time. If he gets blocked, he takes revenge by blocking a device or changing the password of the 192.168.1.1. I,ve got him there... but the ultimate security issue netgear could takkle is this issue. I've just given up.... I'm paying for someones internet
- michaelkenwardJul 05, 2021Guru - Experienced User
Which passwords? Wifi?
I find it hard to see who someone can do that unless they are on your local network.
If you change the router's admin password to something complicated, unless you have enabled Anywhere Access, and they know the complicated username and passwords for that cloud service, they have to be on your network to change it to something else.
So I'm having a hard time understand what your problem is.
Which issue would that be?
Tell us exactly how this person breaks into your system and maybe someone can begin to see how you might fix it.
If you change the admin username along with the SSID and passwords for the wifi, it is hard to see how someone can break in from the outside world. Friends and family, or course, are a different matter.
How? I haven't got a clue. I used to be an admin, if I used to be a hacker maybe I could give you an answer.
