dougjp
May 21, 2020Tutor
Suggestions for Upgrading a N750 N Dual Band To ?
The N750 still works, however looking to upgrade to something 'better'. Reasons are; (a) the 750 is over 7 years old, (b) looking to increase my internet speed package and thinking that will expose w...
- May 22, 2020
Thanks, yes I needed directions around this place, and they are helpful. :smileyvery-happy:
michaelkenward
May 22, 2020Guru - Experienced User
A good place to start is with the product pages. Fill in your needs and circumstances, and see what comes up.
Routers here:
Wifi Router | Wireless Routers for Home | NETGEAR
Fancier stuff with a focus on wifi here:
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
See what takes your fancy, and what fits in with your budget. Then check this place for users views. (But remember this place is where people bring problems, not praise.) And see if you can find a review site that covers what you are thinking of buying.
- dougjpMay 22, 2020Tutor
- michaelkenwardMay 22, 2020Guru - Experienced User
Whatever you do, don't get sucked into anything too complicated.
What with your powerline setup, and the intended us, you don't need lots of bells and whistles, especially the newest wifi stuff which seems to be causing great grief as the standard settle down. You are right to beware AX.
I'd say stick to your budget. For $200 you can get something of a workhorse nature.
I am happy with my ageing R7800, one of the least troublesome routers discussed around here.
By the way, you may not need anything better to work with a faster Internet service. The WNDR4000 is up to most things, unless you are going to Gb.
Thanks again for more excellent advice!
I've been researching for hours, and for my needs, my existing 60 mbps download service is probably enough. I only get 20 mbps through powerline which I guess isn't an unusual drop, and getting more mbps from my ISP was an attempt to 'force through' better speed in the powerline, but that may not happen.
Another thing, I'm reading reviews about people having hours of problems with Netgear setup, because like me they didn't own a smartphone where the new Netgear app has to go, is by far my biggest concern about getting anything.
