dougjp
May 21, 2020Tutor
Suggestions for Upgrading a N750 N Dual Band To ?
The N750 still works, however looking to upgrade to something 'better'. Reasons are; (a) the 750 is over 7 years old, (b) looking to increase my internet speed package and thinking that will expose w...
- May 22, 2020
Thanks, yes I needed directions around this place, and they are helpful. :smileyvery-happy:
dougjp
May 22, 2020Tutor
Thanks again for more excellent advice!
I've been researching for hours, and for my needs, my existing 60 mbps download service is probably enough. I only get 20 mbps through powerline which I guess isn't an unusual drop, and getting more mbps from my ISP was an attempt to 'force through' better speed in the powerline, but that may not happen.
Another thing, I'm reading reviews about people having hours of problems with Netgear setup, because like me they didn't own a smartphone where the new Netgear app has to go, is by far my biggest concern about getting anything.
michaelkenward
May 22, 2020Guru - Experienced User
Which Powerline? Faster Internet will do nothing for plugs that are already at their limit.
Newer plugs aren't just faster over the mains, they also have Gb LAN ports. Good for the devices you connect.
My PLP1000 plugs do a lot better than 20 Mbps. I use them to run an Orbi router in AP mode. Gets >60 Mbps, my Internet speed.
New plugs might be a cheaper upgrade then a router. Bit that depends on the use. My TV streaming happily runs on slower (AV500) plugs. The TV streaming hardware delivers no faster than 100 Mbps.
Experienced users go nowhere near a smartphone for setup. Browser graphical user interface (GUI) all the way. If you are used to that one the WNDR4000 stick with it.
Orbi tries to force mobile apps on us, which is one reason to avoid it.
- dougjpMay 22, 2020Tutor
What can I say, incredible advice! Thank you!
I always though it was the house wiring that was solely responsible for the big speed drop with powerline. Never thought of the powerline itself being part/all of the bottleneck. So I looked into my powerline and, it was bought over 6 years ago, and is a Trendnet 500 mbps.
I'm going to replace that now, then look at buying a new Netgear router shortly after that. Yes I find the Browser GUI to be just fine. I'm looking at AC1750 and AC1900.
- michaelkenwardMay 23, 2020Guru - Experienced User
I had AV500 plugs, still do for my TV streaming, but moved to PLP1000 when I decided to use them for the Orbi AP. The 1000 Mbps LAN ports also help.
Remember, you can also get plugs with an integrated wifi AP at the "remote" end, just in case you have devices there that could benefit from better wifi.
Also check to see if you could use plugs with a pair of LAN ports at the far end. I had to buy a singleton from a different brand to get that.
Netgear and some other makers don't sell single plugs. So it helps to work out what you need before you part with your money.
Good enough for most purposes. Check comments around here. The original R7000 was Netgear's mainstream router for a while. The R7000P has been a bit more problematic, although mine has worked fine.
But, as I said, the cognoscenti rate the R7800 (AC2600) as the current workhorse model. Mine has been flawless.
- dougjpMay 28, 2020Tutor
Just wanted to update you and thank you again. Just installed a new Netgear dual ethernet port powerline, and my internet speed improved by over 50%. I'll give it a while before any further upgrading.
