MelJim
May 11, 2021Guide
Swap Frontier router with Nighthawk X10
How do I go about swapping my Frontier Fios router to the Nighthawk X10 R9000?
- May 12, 2021
thats a gateway/router combo device. Meaning its needed to connect to your frontier setup as a modem at minimum.
You can put it in bridging mode or IP passthrough mode.
that sets it up as a modem only device. Then you'd simply connect the R9000 to it and set it up as normal.
Or you can contact frontier to see if they have any modem only devices or whats compatible with their service for modem only devices.
May 12, 2021Guru - Experienced User
What frontier router is it?
If its a simple router, it shouldn't be hard.
But if its a gateway/router device, then you might not be able to.
Details are key here.
MelJim
May 12, 2021Guide
My apologies, the Frontier router is an Arris model NVG468MQ.
- plemansMay 12, 2021Guru - Experienced User
