SRavetti
Nov 12, 2021Aspirant
switching to IPv6
im having issues switching from ipv4-ipv6 when i enter the site to get into router setting the user name admin and password password dont work....my xbox wont connecto using ipv4 for some reason , ca...
Nov 12, 2021Guru - Experienced User
what modem/gateway do you have?
What firmware is on it?
Do you have ipv6 enabled?
SRavetti
firmware V1.0.4.100
modem is from spectrum if that helps
and no i dont have ipv6 enable as i cant log into the router
- plemansNov 12, 2021Guru - Experienced User
Is it giving you incorrect password/login result?
When you first set it up, it asks you to change the password.
So if you don't know your password, then you'd need to use the password recovery option.
If you didn't set it up, then you'd need to factory reset to get back in.
- SRavettiNov 12, 2021Aspirant
so i just spoke with spectrum they said i need a cat6 ethernet cable and it should work just fine, so im goin to run out and get one and see if that changes anything, im almost positive but before i moved with same router and modem i was able to hardwire using this cord with existing equipment
the cable shouldn't impact ipv4-ipv6 settings. It also shouldn't impact your password
- SRavettiNov 12, 2021AspirantMy username and password isn’t what I renamed the network is it? Like what people use to connect to my wife?
There's the user name/password to log into the router and theres the ssid and password.
Ssid is for the wifi
