cyberwasp
Sep 29, 2021Star
Synology nas Pihole
Recently Cable upgraded their service that included a pos router. It was suggested I purchase my own. I got a Netgearnighthawk AX5400 (RAX50) which doesn't seem to appear in the above Model list, go...
- Sep 30, 2021
plemans wrote:
My NAS IP is 192.168.1.2 and is static. In the Pihole setup under Serverip it's set to the same NAS adress. However it keeps starting/restarting. I followed this tutorial, "How to Setup Pi-hole on a Synology NAS using Docker! - YouTube. the first time a few months ago and it worked.Then for some reason it started this. So I figured, "delete it and start over. As soon as I put in my nas IP in ServerIP it start/stops over and over---what stops/starts over and over again?Am still learning the lingo. What modem/gateway are you using? Cable modem into router? Your router is connected to something providing internet service. What device is that?
plemans. I finally got everything back to working. I first shut everything down and reset the modem and booted the PC and then the NAS. I then deleted Pihole and it's directories. Reistalled pihole and made sure it was stable as the previous one was stopping and starting again. I then went into the router and it let me set the DNS to point to the NAS, "wouldn't before." I also reconnects a few wireless cams successfully.
My apologies for the confusion on my part as I've had my head stuck in Photoshop for the last 10 years and haven't paid much attention to tech. Old age sucks as far as memory goes. I used to know all of these terms and could breeze right through them.
Sep 29, 2021Guru - Experienced User
You can set the dns for the ip off the nas.
I've done it on my pihole as well.
what error are you getting?
How do I set static Domain Name System servers on my NETGEAR router? | Answer | NETGEAR Support
reason you couldn't find yours is you posted in the nighthawk AC forum and not the AX forum.
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
cyberwasp
Sep 29, 2021Star
plemans wrote:You can set the dns for the ip off the nas.
