cyberwasp
Sep 29, 2021Star
Synology nas Pihole
Recently Cable upgraded their service that included a pos router. It was suggested I purchase my own. I got a Netgearnighthawk AX5400 (RAX50) which doesn't seem to appear in the above Model list, go...
- Sep 30, 2021
plemans wrote:
My NAS IP is 192.168.1.2 and is static. In the Pihole setup under Serverip it's set to the same NAS adress. However it keeps starting/restarting. I followed this tutorial, "How to Setup Pi-hole on a Synology NAS using Docker! - YouTube. the first time a few months ago and it worked.Then for some reason it started this. So I figured, "delete it and start over. As soon as I put in my nas IP in ServerIP it start/stops over and over---what stops/starts over and over again?Am still learning the lingo. What modem/gateway are you using? Cable modem into router? Your router is connected to something providing internet service. What device is that?
plemans. I finally got everything back to working. I first shut everything down and reset the modem and booted the PC and then the NAS. I then deleted Pihole and it's directories. Reistalled pihole and made sure it was stable as the previous one was stopping and starting again. I then went into the router and it let me set the DNS to point to the NAS, "wouldn't before." I also reconnects a few wireless cams successfully.
My apologies for the confusion on my part as I've had my head stuck in Photoshop for the last 10 years and haven't paid much attention to tech. Old age sucks as far as memory goes. I used to know all of these terms and could breeze right through them.
Sep 29, 2021Guru - Experienced User
My NAS IP is 192.168.1.2 and is static. In the Pihole setup under Serverip it's set to the same NAS adress. However it keeps starting/restarting. I followed this tutorial, "How to Setup Pi-hole on a Synology NAS using Docker! - YouTube. the first time a few months ago and it worked.Then for some reason it started this. So I figured, "delete it and start over. As soon as I put in my nas IP in ServerIP it start/stops over and over---what stops/starts over and over again? You'll enter the servers IP for the docker pihole address into the netgears DNS address for internet setup. showing pictures of what you're doing and what happens helps
cyberwasp
Sep 30, 2021Star
- cyberwaspSep 30, 2021Star
I hope you don't mind. I tried to find the AX model forum but still not seeing a forum list. either I'm blind or there is not a way to get there.
Had a recent set back. was trying to get my wireless Raspbery pi connect and swapped the two DNS entries to see if puting it as primary would work. When doing so the dns returned as blank. I forget what I did to get the entries to stay. when I hit apply and the page reloads, they are gone.
- plemansSep 30, 2021Guru - Experienced User
I just tried it on a RAX200, an RAXE500, and a RBK752 (don't have your model) and it all worked fine on mine.
Have you tried a different browser/pc?
Tried 3 browsers and 2 pc's plus my phone. The only way it would let me is a complete reset. start from scratch. Than tonight, tech support had me run an update. Now even the reset won't let me! BTW: It's an RAX50 for which I didn't see in the model list either.
Ok, just got off with tech support and we tried something. I logged into router page went to Internet> DNS and it was blank. Went back to home and then back tro internet and the IP's I put in showed this time and let me edit them. Am thinking it's a bug of sorts as she's having me watch it and am expecting a call form a different tech, "higher up," I guess as he wants to record the whole routine.
Wish you were near so I can take you to dinner or something for the help. Thanks again!!!
