ServiceGear
Mar 16, 2022Star
T-Mobile NOK 5G21 Gateway and Netgear R8000P - Now DNS Problems
I was successfully using my Netgear Nighthawk R8000P router to connect to the internet through my Spectrum cable modem for a couple years. When I saw T-Mobile had a cheaper internet service than Spec...
- Mar 18, 2022
Summary: I was having trouble getting to some subset of internet sites. I was getting what looked like DNS errors of some sort. I THOUGHT that this problem started happening when I started switching from my Spectrum internet service to T-Mobile's internet service. I THOUGHT things started going bad when I connected my T-Mobile NOK 5G21 gateway to my Netgear R8000P router. What I forgot about was, not too long ago, I DID upgrade my Netgear router to the most recent firmware version (V1.4.2.84_1.3.42).
In plemans' reponse to my posts, he suggested that the most recent version of the Netgear firmware might be having (or causing) some trouble with DNS resolution. Plemans suggested I update the Netgear firmware to an older version. So I downloaded firmware version V1.4.1.68_1.3.28. This was the firmware version immediately prior to the recent firmware upgrade. Much to my surprise and delight, this seems to have fixed this problem.
I am still working through some of the options plemans suggested regarding how to connect the T-Mobile gateway to the Netgear router. So far, the T-Mobile gateway configuration screens do not support bridge mode, a DMZ (at least, as far as I can tell). I am not sure I want to put the Netgear router into AP mode (I will lose too much functionality). I have connected (via ethernet cable) the T-Mobile gateway to the Netgear router and it all seems to be working OK. But I am almost certainly getting double NAT in this configuration (again, as plemans suggested).
Bottom Line: The main problem with the DNS resolution I think as been solved.
MANY THANKS to plemans for providing what looks like the solution to my problem.
michaelkenward
Mar 17, 2022Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
