00derek
Jan 10, 2025Tutor
T-Mobile TMHI gateway + R6700 router
New TMO-G4SE internet gateway installed 6 days ago (1/3), everything worked out of the box. I disconnected the ethernet cable from my Cox modem (to my Netgear R6700 router), and connected it to the L...
- Jan 11, 2025
00derek wrote:
p.s. for this particular problem, other sources suggest turning off wifi on the gateway? Is that just to avoid interference? Since most times people would place routers very close to gateways?
Turning off the wifi will reduce/eliminate interference but it will not prevent the two routers from getting in the way of each other.
what about wifi extenders that were linked to the router before? they seem to be unavailable now.
That is probably a NAT issue. Nothing to do with interference.
AP up and running, but I'm not convinced the problem is fixed yet, still having some devices lose internet.
You'll have to provide details of what is actually happening. Sadly "not convinced" doesn't give us much to go on.
When experimenting with your setup remember to restart things as required.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Just another user with time on their hands.
00derek
Jan 11, 2025Tutor
Kitsap
Jan 11, 2025Master
00derek wrote:p.s. for this particular problem, other sources suggest turning off wifi on the gateway? Is that just to avoid interference? Since most times people would place routers very close to gateways?
If your router and gateway are 30-50 feet apart, you will not have any interference.
Are you using the same SSID and password for each transmitter (router and gateway)? It is OK if you do.
I do not know how much channel configuration control you have over the 2.4 GHz and 5 GHz bands on your gateway. Suggest you configure different channel numbers between the two transmitters. For the 2.4 GHz band, choose channels 1, 6, or 11 on one device and then one of the other two on the other device. Avoid auto channel selection on one or both devices if possible.
Do the same thing on the 5 GHz bands. Select channel 44 on one device and 56 on the other. There is no auto selection option on the 5 GHz band.
You should reset and reconfigure your Wi-Fi extenders since you configured your router as an access point. You can still tie the extenders back to the access point.
The network restart sequence michaelkenward laid out is very important. Your gateway is a combination modem/router. The 2 minutes wait time is a minimum. Give your devices ample time to connect and stabilize after they are powered up. Look for LED indicators that show an internet connection is available before moving ahead to the next step.
- 00derekJan 13, 2025Tutor
I went back to router mode on the Netgear and didn't connect it to the TMO gateway - I wanted to get all the smart home devices working again with Alexa. I essentially scrubbed all the changes and started over from a place where I know everything is working. I power cycled all the smart home devices to get them re-connected to wifi, and I think I will need to do that again when the Netgear changes to AP mode.
I'm about to start over - change Netgear to AP mode then connect it to the gateway - but another question arises.
I have another old router (Linksys) in AP mode connected to the Netgear router via ethernet. I use it for a TV (via ethernet) in a different room, and have some nearby device connected to its wifi.
When the Netgear changes to AP mode, should I leave the Linksys in AP mode or change it to bridge mode, or what?
Do I really need to disable wifi on the TMO gateway when the Netgear is in AP mode? That's what all the articles and tribal-knowledge say, but is it just to avoid interference? As I said, the gateway and router are 30-50 feet apart.
Much appreciate all the advice, cheers
- KitsapJan 13, 2025Master
00derek wrote:I went back to router mode on the Netgear and didn't connect it to the TMO gateway - I wanted to get all the smart home devices working again with Alexa. I essentially scrubbed all the changes and started over from a place where I know everything is working. I power cycled all the smart home devices to get them re-connected to wifi, and I think I will need to do that again when the Netgear changes to AP mode.
Leave the Linksys in AP mode. Power it down and disconnect the Ethernet cable while you are making the changes to the Netgear device. When you are done making changes, reconnect the Ethernet cable and power it back up.
No.
Magic thank you.
So far so good, all the SSIDs are up and look stable so far.
The Linksys manual says to plug the ethernet cable from the Netgear into a LAN port and not the Internet port, which is what I did. But the Netgear articles on AP mode didn't mention this - ethernet from the gateway goes to the internet port on the R6700, and it seems to be working. Thoughts or comments?
