Two_characters
Feb 01, 2022Tutor
Taking ethernet output and distributing it
I have problems with line drops on my VDSL2 incoming line. I also have a modem/router from another manufacturer which can fall over to a SIM provided broadband so I don't lose connectivity. It is not...
- Feb 02, 2022
then try the 2nd device in access point mode. That leaves the primary router controlling lease/dhcp
Two_characters
Feb 01, 2022Tutor
Solved: you have to disable DHCP BEFORE you connect to the other router. It still seems to give out IP addresses but it all works so I'm not poking the beast any further.
Feb 01, 2022Guru - Experienced User
your correct, if both are running in router mode, it causes a double nat. We usually have a couple things we recommend for fixing that. Disabling dhcp on the netgear is one route.
Great investivative skills.
If you mark it solved, it keep others from trying to solve the problem.
- Two_charactersFeb 02, 2022Tutor
Hi, thank you for your reply. It hasn't quite worked, as the issue of lease time raised its head. I need to cut all the leases to 5 minutes and start again as my sttaic IPs all got broken. So not quite solved yet.
plemans wrote:your correct, if both are running in router mode, it causes a double nat. We usually have a couple things we recommend for fixing that. Disabling dhcp on the netgear is one route.
- plemansFeb 02, 2022Guru - Experienced User
- Two_charactersFeb 04, 2022Tutor
Brilliant, thank you. I needed to reset the router to purge all the NVRAM and so on but once that was done it has settled into AP mode beautifully. I had originally been concerned that the output would only be on wifi as the manual is a bit unclear but I now have great 1Gb ethernet as well. I have saved the configuration for both purposes. Always save your configuration somewhere - it's essential. Many thanks.
