Angelo0327
Jan 24, 2022Follower
Telekom Magenta
Hallo, ich suche ein Switch (16 Ports) für Telekom Magenta TV. Das heißt ich möchte LAN Stecker rein machen und nichts großartiges machen müssen und ich hoffe es ist einfach ein Update zu machen. ...
Jan 24, 2022Guru - Experienced User
Englisch Bitte
What model NG switch are you referring to?
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with Switch products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Switches/ct-p/business-switches
Thank you.
- microchip8Jan 24, 2022Master
I assume a simple, unmanaged 16-ports switch like the JGS516v2 will do?
