CrimpOn
Oct 21, 2019Guru - Experienced User
Telnet on R7000?
Sorry if "this horse died a long time ago". After much searching, I am unable to determine that telnet can or cannot be enabled on the Nighthawk R7000, firmware 1.0.9.88_10.2.88 (current). I loc...
- Oct 21, 2019
> [...] I had not realized that UDP would return an ACK. [...]
UDP itself doesn't, but the program which listens for the special
Telnet-enable message (Looks like "telnetDBGD" on my D7000) seems to.
(I didn't see it documented anywhere, but when I ran the experiment, I
detected a response when the request succeeded.> [...] NTE does not attempt to open a telnet session, [...]
That's not its job. All it does is send the Telnet-enable message.
If that works, then the router firmware should enable/run its Telnet
daemon ("/sbin/telnetd"). Then, a normal Telnet client will have
something with which to talk.> My conclusion (so far), is the current R7000 firmware isn't running
> telnet, or at least isn't listening on port 23. [...]
Right. A "connection refused" complaint from a Telnet client which
tries to connect to it would be another clue. By default, the router's
Telnet server is disabled, but these Telnet-enable programs are supposed
to send the magic Telnet-enable message which should persuade the router
to enable its Telnet server. And that's what's not happening.> [...] Not answering SSH, either.
I've never heard of a Netgear router allowing an SSH connection.
> [...] Do I need to scan all possible ports, and maybe Netgear put
> telnet or ssh somewhere else?I doubt that that would help. Many things are possible, but I
haven't seen any evidence that Netgear uses any odd-ball ports for this
stuff.Around here, on a handy D7000 (vaguely similar to an R7000), for
example:# ps | grep -i telnet 781 root 0 SW [ telnetDBGD ] 782 root 0 SW [ acktelnetDBGD ] 2178 root 616 S telnetenabled 10.0.0.1 506A03E9AE88 admin password 25785 root 1144 S /sbin/telnetd 27377 root 1140 S grep -i telnet
I know nothing, but I'd guess that the "telnetDBGD"+"acktelnetDBGD"
pair are what handle the Telnet-enable message (and the response to
it?), and "telnetenabled" is what actually enabled the Telnet daemon
("/sbin/telnetd").As for receptive ports:
# netstat -an | grep ' LISTEN ' tcp 0 0 0.0.0.0:33344 0.0.0.0:* LISTEN tcp 0 0 127.0.0.1:14369 0.0.0.0:* LISTEN tcp 0 0 0.0.0.0:20005 0.0.0.0:* LISTEN tcp 0 0 10.0.0.1:1990 0.0.0.0:* LISTEN tcp 0 0 10.0.0.1:53 0.0.0.0:* LISTEN tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN tcp 0 0 :::80 :::* LISTEN tcp 0 0 :::23 :::* LISTEN
All of which, although potentially interesting, tells us nothing
about why this stuff stopped working when it did, or whether that
change was intentional, or just another recently introduced bug.> [...] my hope is that someone on the forum has the expertise to put me
> out of my misery.Sadly, loading older firmware may be all that I can suggest.
Waiting for a useful response from Netgear to complaints here about an
unsupported feature doesn't seem to have been very productive so far.
michaelkenward
Oct 24, 2019Guru - Experienced User
- CrimpOnOct 24, 2019Guru - Experienced User
michaelkenward wrote:
http://routerlogin.com/debug.htmSorry, not there on my Nighthawk R7000.
- antinodeOct 24, 2019Guru
On mine, with V1.0.9.60_10.2.60, the page ("debug.htm") is there, but
I see nothing about Telnet on it.After reverting to V1.0.9.42_10.2.44, "debug.htm" mentions Telnet,
but only in code which was commented out. (But a Telnet-enable program
like NTE still worked with that version.)More examples of "continuous improvement", Netgear style.
