bimox
Jun 01, 2022Follower
Telnet on R8000
Hi, I searched all the forum for a definitve answer, but i found very few regarding R8000. I have 1.0.4.84 and I'm trying to enble telnet in order to configure WOL from internet. - debug page doesn...
Jun 01, 2022Guru - Experienced User
I believe for security reasons, NG has removed telnet from all of it's products.
michaelkenward
Jun 02, 2022Guru - Experienced User
That happened with firmware updates.
If this is for a temporary issue, reverting to older firmware might work.
Then visit here:
http://routerlogin.com/debug.htm
You may have an option there to enable telnet.
It is not a good idea to leave the router on older firmware without the security updates that came with newer releases.
