kippelsa
Nov 20, 2021Follower
Terrible wifi range on C7800
When i bought this model almost 2 months ago everything was working perfectly fine. The wifi range covered my entire house no problem and speeds were fast. Something happened a couple days ago where ...
michaelkenward
Nov 21, 2021Guru - Experienced User
kippelsa wrote:
Something happened a couple days ago where now i cannot even detect wifi 15 feet away from my unit. Internet through ethernet cable is perfect, just wifi range is next to zero. Any ideas on where to start looking?
Any wifi interference from the neighbours?
Have you tried playing around with the wifi bands?
Is this with all wifi clients?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
The manual will tell you where to change the wifi settings.
Have you noticed a difference from 2.4ghz to 5ghz?
or has range on both bands dropped?
What actual speeds do you get over both?
What speeds do you get wired into the router?
If you bought it 2 months ago, you should be within your 90 days of free support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
