kkworthy
Sep 09, 2020Tutor
TFTP Issues - Bricked R6700v2
I found below link to attempt to recover my router after a failed firmware upgrade yesterday. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP First...
- Sep 09, 2020
I was able to fix the issue by utilizing the "nmrpflash" tool as a last ditch effort
DarrenM
Sep 09, 2020Sr. NETGEAR Moderator
You may need to contact support at this point if your router is still under warranty.
https://www.netgear.com/support/contact.aspx
DarrenM
kkworthy
Sep 09, 2020Tutor
Hey Darren,
Thanks for the reply.
Unfortunately this is out of warranty. It's a bit disheartening to know that a firmware update provided by netgear would somehow cause me to buy a brand new router.
- kkworthySep 09, 2020Tutor
