Baldr333
Nov 09, 2020Follower
TFTP Recovery not working "connect request failed"
So, tried updating my firmware for my router, and it ended up glitching out halfway through. Found threads on using TFTP to reflash an update to the router, and have everything set up right, but every...
antinode
Nov 09, 2020Guru
> [...] it ended up glitching out halfway through. [...]
Not a very detailed description of what happened, or what the router
does now.
> [...] Found threads on using TFTP [...]
Thanks for the helpful links.
> [...] have everything set up right, [...]
It's nice that you're happy, and you could be right, but, with no
actual evidence, not everyone will share your confidence.
> [...] Checked ping between static ip and router and it was fine, [...]
Actual "ping" command and its output? Copy+paste is your friend.
> [...] entered the TFTP command [...]
Can't see it. Copy+paste is your friend.
> [...] right at the small window where the server pings in on reboot,
"small"? Try varying the timing?
> [...] using the most recent firmware file for my exact router. [...]
Can't see that file name, either, but I'd expect an error like
"connect request failed" to be independent of the file.
