Baldr333
Nov 09, 2020Follower
TFTP Recovery not working "connect request failed"
So, tried updating my firmware for my router, and it ended up glitching out halfway through. Found threads on using TFTP to reflash an update to the router, and have everything set up right, but every...
Havok970
Apr 18, 2021Tutor
Greetings,
Wireshark confirmed my suspicions. For the model above, the router needs to have a solid orange power and a link LED on the Lan port you are plugged into, NOT blinking white power LED despite the windows directions stating otherwise. You still can't ping the gateway, but TFTP WILL go through. To review, you still may need to factory reset the router, but to upgrade FW, it needs to boot NORMALLY. Again, my advice for the long term if at all possible is to use RouterOS or something else that isn't proprietary consumer-grade garbage.
- Havok970Apr 18, 2021TutorOne last thing:
The router came up with all of its previous settings, so yes, this whole thing is a GIANT boondoggle.- antinodeApr 18, 2021Guru
> [...] I followed the one directions that are actually relatively
> precise, [...]Were those directions as precise as your description of where to find
them?
> [...] You still can't ping the gateway, [...]I still can't see your "ping" command, or its output.
> whole thing is a GIANT boondoggle.I would not expect loading new (or same) firmware to perform a
settings reset. Did _you_ expect that? (Why?)"boondoggle"? Does your router still not work, or is this some new
meaning for "boondoggle"? And why report it here, instead of in your
own thread?Context:
- Havok970Apr 18, 2021TutorYou were the one who linked to them, so I agree I was wrong to follow any advice from you. Luckily, I'm a networking professional who can use tools like Wireshark, so I was going to solve it regardless of bad procedures and harassment by what appears to be a pedantic shill. Or maybe he just has no life. Regardless, stay away from all cheap proprietary consumer-grade gear is the advice I must re-iterate, or deal with "gurus"
