MikioBear
Apr 23, 2021Tutor
The 2.4mhz band onmy R8500 keeps disconnecting every 3-4 days
Recently the wifi signal of my Nighthawk R8500 turns off every 3-4 days. Usually it's just the 2.4mhz band but sometings both 2.4mhz and 5mhz turn off. The router lights stay on and are white. To...
Apr 24, 2021Guru - Experienced User
Does it happen if you disable smart connect?
- MikioBearApr 24, 2021Tutor
Although the router did Not disconnect when I switched ion Smart Connect, I guess I can try that and see what happens.
- MikioBearApr 28, 2021Tutor
Yes it shut down tonight after I disconnected the Smart Connect this past Sunday. So the signal stayed connected a little over 3 days until shutting down again. What's different than last time is that when I restarted my laptop it reconnected to 5mhz band but the 2.4mhz didn't even appear on the wifi list. So again I amout of ideas.
- plemansApr 28, 2021Guru - Experienced User
did you ever try a factory reset and reinstall?
I did Not do a factory reset or uninstall/reinstall.
I pressed the black button on the back Or I unplugged it and plugged back in the wall.
So I don't hvae to look it up, how do I perform a factory reset?
