msidefx
Feb 12, 2021Aspirant
The information you entered does not match what is saved on the router. Please enter it again.
I purchased this R7300 used router from Ebay. When using the user login of "admin" and password as "password", after 2 attempts it brings me to Router Password Recovery screen. Here it asks for the r...
msidefx
Thanks for the reply.. It helps if you plug the network cable into a LAN port and not the WAN... So i'm in configuration now.
Trying to set the R7000 in repeater mode but I don't see the option of Advanced Setup > Router/AP/Bridge/Repeating Mode as stated here https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router. This is a netgear support article.
Do you know if an R7000 supports repeater mode? If so, where do I find it? This community article says repeater mode does NOT exist..
I'm so confused..
schumaku
Feb 13, 2021Guru - Experienced User
Hard to imagine a KB article (ID: 24108) dated or updated 06/08/2020 for the R6700, R6700v2, R6900 and R7000 isn't appropriate.
There were features removed from the R7000 - but no word from this. "Starting firmware version V1.0.9.88 for the Nighthawk AC1900 (Models: R7000), following legacy features have been removed: iTunesServer, Kwilt Photosharing, Time Machine Backup, TiVo support for media sharing, DLNA, and Downloader feature (which was in beta)."
msidefx wrote:This community article says repeater mode does NOT exist..
If reading carefully, this does talk of the R7000P ... which is not the same router like the R7000.
msidefx wrote:I purchased this R7300 used router from Ebay.
And then again, the R7300 is not an R7000.
- msidefxFeb 13, 2021Aspirant
My mistake. Yes I have the R7300.. There is no setting for repeater.. Thanks..
