James282923542
Feb 23, 2022Follower
The Router cannot regonize Hard drive
My router Nighthawk R6700 cannot recognize 8TB Seagate Backup Plus Hub. But the router can recognize a 1GB flash drive. I use the same computer and the same setting. Do you have any idea why? Thanks ...
schumaku
Feb 24, 2022Guru - Experienced User
A (very) possible reason is that the Netgear USB storage implementation (on the routers, the ReadyNAS) does not like the presence of USB Hubs.
