whooops61
Mar 03, 2022Tutor
There is no disk in the drive...
When I start up my PC, I now get a loud thunk sound with this message... "There is no disk in the drive. Please insert a disk into drive \Device\Harddisk13\DR13." Any one know what mig...
- Mar 16, 2022
PROBLEM SOLVED...
In Netgear genie, Go to "My Media" tab on the left...
Click on the "Settings" tab on the right...
Now make sure your "Video, Audio & Picture" destinations are all valid.
My Default Video Folder was set to O:/ however I do not have an "O" drive on my system thus giving me an error message on startup.
Life is good again!
Mar 03, 2022Guru - Experienced User
Looks like a computer issue.
Are you having hard drive issues?
whooops61
Mar 05, 2022Tutor
No I am not having hard drive issues, thanks.
I understand this is not support. I was only asking to see if anyone else is having this issue with NETGEAR Genie. Netgear support does not cover this topic and directed me here.
- plemansMar 05, 2022Guru - Experienced User
If you uninstall it, does it still make the sound and give you the error?
(not re-install, just uninstall.)
