muyakea's avatar
muyakea
Follower
Dec 18, 2021
These routers are junk
Sick and tired of the wifi dropping out, impossible to get any reliable help other than 'reboot'.
Be spending my Xmas break getting rid of this piece of crap and go with another provider.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    If you want to tell people about your unfortunate experiences, they might pay more attention of you told them which Netgear router has upset you.
    I guess you were in such a hurry to complain that you picked the A7000 WiFi USB Adapter listed in your footer because it was the first thing you saw in a pop-down list.
    Let's hope that it really was the router that caused your problems and not something else on your network, the modem in front of it, for example..
