andym56
Apr 22, 2021Tutor
This DFS channel is not allowed to use because the Radar was detected before. But I can't change it.
The error message always displays, but I cannot make any changes to the wireless settings - it just complains about the radar. That happens even when I try and disable the channel using DFS. ...
Apr 22, 2021Guru - Experienced User
Not sure what you mean by "that happens when I try and disble the channel using dfs"
DFS isn't something you can disable. You can use non-dfs channels. But if there's active radar, it isn't going to allow you to use dfs channels
- andym56Apr 22, 2021Tutor
I meant - I tried to disable the 5 ghz channel that was using DFS.
Simply selecting a non-DFS channel results in that error, so I thought I'd try that.
Whatever I do I get tat error message when I click on apply.
