andym56
Apr 22, 2021Tutor
This DFS channel is not allowed to use because the Radar was detected before. But I can't change it.
The error message always displays, but I cannot make any changes to the wireless settings - it just complains about the radar. That happens even when I try and disable the channel using DFS. ...
andym56
Apr 22, 2021Tutor
I meant - I tried to disable the 5 ghz channel that was using DFS.
Simply selecting a non-DFS channel results in that error, so I thought I'd try that.
Whatever I do I get tat error message when I click on apply.
Apr 22, 2021Guru - Experienced User
Tried a factory reset and reinstall?
- andym56Apr 22, 2021Tutor
It's been like it for years, through many resets ans reconfigs. Always the same.
- plemansApr 22, 2021Guru - Experienced User
what region are you?
Is there radar around you?
- andym56Apr 22, 2021TutorThere is radar about 5 miles up the road at an army airfield. So I am prepared to believe DFS is out of the question. My problem is, I can’t select a non dfs channel because I get the error.
