nighthawkguy
Aug 13, 2021Aspirant
This serial number is already registered to another customer. Please email NETGEAR support Customer.
Bought this router used. This serial number is already registered to another customer. Please email NETGEAR support Customer.service@netgear.com for help. Email sent. Cannot update the router wit...
nighthawkguy
Aug 14, 2021Aspirant
You should still be able to log in manually to the router to update it.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
Step 8 : Enter the router admin user name and password.
The default user name is admin. The password is the one you specified the first time you logged in. The user name and password are case-sensitive.
Already set up and don't have the information to log on.
Will try fixing the double NAT once the router is updated
Aug 14, 2021Guru - Experienced User
Already set up and don't have the information to log on.-----That's why I'd say factory reset. it gets you back to the defaults so you can log in and change them. Then update.
