MJHgamer
Aug 19, 2024Aspirant
This site can’t be reached
Nighthawk X6 R7900 Firmware Version V1.0.4.46_10.0.53 I keep getting this error at most sites and quite often refreshing won't load. Plugging directly into the Arris CM3200A modem, there is no iss...
Aug 21, 2024Guru - Experienced User
Re-look at your numbers you typed in. Not sure if its the photo quality but the DNS numbers aren't matching from all the numbers. Again, it could be the photo
