Rokyan
Jan 22, 2022Star
This Site Can't Be Reached / Garbage Router??? Solution buy a different brand of router?
Firmware upgrade and now, "Site Can't be reached" on multiple sites I use daily for work. I have tried all the solutions I have seen, Flush DNS and all the others. NOT WORKING. I saw the suggesti...
michaelkenward
Jan 23, 2022Guru - Experienced User
To which version?
Your description of the problem does not give much to go on.
What is the exact message that you see and what you you done to troubleshoot it.
Only you know what you tried. Did it include a factory reset?
Rokyan wrote:
I saw the suggestion to downgrade to older firmware but not willing to do that.
You may have to do that if the problem is down to the firmware on your router.
The chances of doing any harm by reverting to earlier firmware are vanishingly small.
Trying an earlier version would at least confirm that this is the problem. It does not have to be a permanent move.
Rokyan
Jan 23, 2022Star
I love how most people on here respond but don't read. THE LATEST FIRMWARE! V1.0.4.76_10.1.82
If you're going to not read the post and not think, then don't respond.
- michaelkenwardJan 23, 2022Guru - Experienced User
Where do you say that? I can't find it in this conversation.
Forgive us if we don't dive all over the places reading messages elsewhere, if that is where you provided this essential information.
It is meaningless to say "the latest", which you don't seem to have claimed. By the time someone reads that here, we may be several versions on. Only the number, which is also missing from your previous messages here, means anything.
