Rokyan
Jan 22, 2022Star
This Site Can't Be Reached / Garbage Router??? Solution buy a different brand of router?
Firmware upgrade and now, "Site Can't be reached" on multiple sites I use daily for work. I have tried all the solutions I have seen, Flush DNS and all the others. NOT WORKING. I saw the suggesti...
michaelkenward
Jan 23, 2022Guru - Experienced User
To which version?
Your description of the problem does not give much to go on.
What is the exact message that you see and what you you done to troubleshoot it.
Only you know what you tried. Did it include a factory reset?
Rokyan wrote:
I saw the suggestion to downgrade to older firmware but not willing to do that.
You may have to do that if the problem is down to the firmware on your router.
The chances of doing any harm by reverting to earlier firmware are vanishingly small.
Trying an earlier version would at least confirm that this is the problem. It does not have to be a permanent move.
Rokyan
Jan 23, 2022Star
Upgraded Firmware. Common sense would tell most people on this planet that would mean the latests software. Also not willing to use older firmware would again tell someone with common sense it's the latests firmware. If you're still confused you could look at the date of the post.
- plemansJan 23, 2022Guru - Experienced User
Rokyan You realize this is the public support forum where members of the public help out? We're not netgear. We're not paid to be here. If you're going to be rude/snarky with the people trying to help, you're not likely to get help.
- RokyanJan 23, 2022Star
Good, I don't help from clowns who don't take a second to read. They just want to hear themselves speak and of no use to most and it's clear when you read all the posts. Lots of talk, very little real help.
