pinser
Aug 31, 2021Follower
THROTLE SPEED
Currently have a rax45 wifi 6.
On the app i can see speeds to the router at around 475mgps down, i have 400mgps plan through spectrum.
On wifi im pulling around 100-120mgps
But on ethernet to my pc im pulling 75mgps
QOS is off all parental controls are off, traffic meter is off.
Not sure how to allow more speeds come through.
What pc do you have?
What ethernet card does it have in it?
have you check to ensure you have a quality ethernet cable connected between the 2?
Have you checked the port statistics to confirm its connecting at a gigabit rate?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
have you tried a different pc?
What modem do you have?
Have you tried factory resetting/reinstalling the router?
What colour do the Ethernet LEDS on the top show?
