kblgy
Nov 18, 2015Aspirant
time restrictions
hi, so i setup my R7000 so that my kids have access on the guest network only. what i cannot figure out is how to shut it off at a cetain time so they are not staying up in bed watching videos or on ...
- Retired_MemberNov 18, 2015
You cannot turn off guest by schedule, without turning off the primary SSID too. The guest and primary SSID use same radio.
another option is to use Block Service "ALL" use address reservations to assign a consecutive group of IP's to the kids devices. Enter that range of IP's and activate a schedule and wait for the long faces.
Look at the parental control function too.
Retired_Member
Nov 18, 2015You cannot turn off guest by schedule, without turning off the primary SSID too. The guest and primary SSID use same radio.
