CariMarota
Nov 04, 2022Aspirant
Timing out
I have 2 work computers. One has to be connected via Ethernet and the other WiFi. It seems to time out on WiFi after a couple hours. How should the settings be to prevent this. I thought I had selecte...
michaelkenward
Nov 04, 2022Guru - Experienced User
Times out from what?
If this is a wifi adapter on a Windows PC check that it is not set to put the USB port to sleep after a period of inactivity.
Wifi adapter properties
It is easy to blame the router for connection issues when the real culprit is something else on the network. First investigate other possibilities.
CariMarota
I am not set up as an admin so I cannot change that option.
- plemansNov 04, 2022Guru - Experienced User
Whoever is your admin, have them change that. If it can't be changed and thats whats causing it, that can be the issue
