CariMarota
Nov 04, 2022Aspirant
Timing out
I have 2 work computers. One has to be connected via Ethernet and the other WiFi. It seems to time out on WiFi after a couple hours. How should the settings be to prevent this. I thought I had selecte...
Nov 04, 2022Guru - Experienced User
What router do you have?
What modem/gateway is it connected to?
What firmware is on the router?
What do you mean by time out? What actually happens? What error do you get? "time out" doesn't tell us much
CariMarota
I disconnect from the WiFi after a couple hours and have to log back into my vpn. I am using an M6 nighthawk wireless mobile hotspot. My computer just says no internet so then I have to take the battery off my hotspot and reset it and sometimes do a factory reset because the status on the nighthawk states disconnected.
- michaelkenwardNov 04, 2022Guru - Experienced User
CariMarota wrote:
I disconnect from the WiFi after a couple hours and have to log back into my vpn. I am using an M6 nighthawk wireless mobile hotspot.Those things are not like the average Nighthawk wifi router covered in this section. Mobile hotspots have very different settings,
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
You might like to search there for messages related to your problem.
