devansh
Aug 22, 2022Tutor
TLS handshake failure while connecting to OpenVPN server on Nighthawk R7450
I am trying to setup a VPN server on my router so that I can connect to my home internet while traveling. I have enabled the OpenVPN server with the Netgear DDNS and downloaded the configuration file...
- Dec 02, 2023
Hi, unfortunately the only solution is to wait for Netgear to fix it in their next update. And given how old the router is, I dont think it is going to happen. The only workaround I found is to install 3rd party firmware like DD-WRT or wireguard on the router.
