ManyDevices
Aug 05, 2022Follower
Too many devices are "choking" the routers, disabling the wi-fi periodically.
I have two routers: NETGEAR Nighthawk AC1750 Smart Dual Band WiFi Router (R6700) NETGEAR AC1600 Dual Band Gigabit WiFi Router (R6260) The first is connected to my modem. And the second router is...
Aug 05, 2022Guru - Experienced User
Is the 2nd Router in AP mode?
Using far apart channels between the 1st and 2nd router?
What is the distance between the 1st and 2nd router?
How are the wifi configurations set between each router?
