garnak
Nov 15, 2022Aspirant
Too many requests - error when accessing "webinar-sites" - Nighthawk AC1900/R7000
When I access sites like https://webinar.obsidian.dk/ I get the error "Too many requests". The error is there no matter if I connect to the router cabled or using Wifi. (Nighthawk AC1900/R7000 - Firm...
michaelkenward
Nov 15, 2022Guru - Experienced User
garnak wrote:
When I access sites like https://webinar.obsidian.dk/ I get the error "Too many requests". The error is there no matter if I connect to the router cabled or using Wifi. (Nighthawk AC1900/R7000 - Firmware: V1.0.11.126_10.2.112)
If I bypass the router (connecting directly to the ISP) I don't have any problem accessing the site mentioned above.
What modem/gateway/ONT sits between the router and the Internet?
You might like to update your firmware. There have been several since that one.
Visit the support pages:
Support | NETGEAR
That page will have firmware for your device.
Check the section in the manual on updating the firmware.
garnak
Between the modem and the internet: icotera i5801-01
According to the Nighthawk app (iPhone) the firmware is up to date!?
- michaelkenwardNov 15, 2022Guru - Experienced User
Hard to be accurate as that doesn't show up in a search, but according to Google, that looks like a combined ONT/router. Does it also also do wifi and LAN?
If so, this means that you are in classic NAT territory.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
It isn't. Those apps are notoriously unreliable. That is why I told you where to look.
