bparas
Mar 11, 2019Guide
Traffic Meter 0.00 after Daylight Savings Time
Have the R7800 with firmware V1.0.2.62.
After the recent daylight savings time change here in San Francisco bay area, USA, the traffic meter is showing all zeros. And I can't find any screen where ...
- Mar 11, 2019
Thanks for the tip on the Advanced -> Administration -> NTP Settings. Disabled the daylight and manually adjusted to -7 GMT to reflect the right time difference and it works again.
neo1981
Mar 11, 2019Apprentice
I see the same issue on R9000. I vaguely remember Netgear fixing this issue last year. Seems like a regression.
microchip8
Mar 11, 2019Master
You can disable DST in Advanced -> Administration -> NTP Settings
- neo1981Mar 11, 2019ApprenticeYep, aware of that. The point here is that this is just bad software, especially if it's a regression. I hope they fix it, the right way.
- bparasMar 11, 2019Guide
- duckwareMar 12, 2019Prodigy
Don't expect a fix from Netgear. I personally reported this bug to Netgear over a year ago (have a case number and everything), and it is still not fixed. Netgear support is SOOOOOO bad.
- neo1981Mar 13, 2019Apprentice
Noticed there was a firmware update today for R9000 (1.0.4.28) and this issue still not fixed! Ugh.
