bparas
Mar 11, 2019Guide
Traffic Meter 0.00 after Daylight Savings Time
Have the R7800 with firmware V1.0.2.62.
After the recent daylight savings time change here in San Francisco bay area, USA, the traffic meter is showing all zeros. And I can't find any screen where ...
- Mar 11, 2019
Thanks for the tip on the Advanced -> Administration -> NTP Settings. Disabled the daylight and manually adjusted to -7 GMT to reflect the right time difference and it works again.
microchip8
Mar 11, 2019Master
You can disable DST in Advanced -> Administration -> NTP Settings
neo1981
Mar 11, 2019Apprentice
Yep, aware of that. The point here is that this is just bad software, especially if it's a regression. I hope they fix it, the right way.
