Siebels24's avatar
Siebels24
Follower
Mar 24, 2018
Traffic Meter not working
Traffic meter not working it is on but everything says zero running firmware V1.0.2.46
  • Correct question would be: Do you have daylight saving time settings on your router? If yes (I'm almost convinced it is), the traffic meter would always show nulls. Temporarily disable daylight saving time ... and you will experience the magic. Systematic issue on many if not all Netgear Nighthawk routers.
    • schumaku's avatar
      schumaku
      • CTH's avatar
        CTH
        Really good solution. If checking daylight saving time, I can not see the traffic. If I remove checking, I can see traffic. Thanks.
