john1005's avatar
Nov 06, 2016
Traffic Volume Left remains, "0" with enabled/programmed settings
2016-11-06 06.27.33.jpgI installed the router three days ago.  Then I enabled the traffic meter and entered the amount of bandwith, etc (just like I did on old R7000 that recently died).  The traffic volume stays at "0".  What do I need to do to get it to work so I can track my bandwith usage?  Thanks.
  • john1005's avatar
    john1005
    Nov 06, 2016
    That was the problem.  I added more zeros to make it 500 Gb.  The meter now displays the correct values.  Thanks.
  • Retired_Member's avatar
    Retired_Member
    your numbers don't add up you start with 5000 and used 5700 yesterday
    Mine works fine
    • john1005's avatar
      john1005
      Guide
