ThePCNerd
Jun 17, 2021Follower
Transfer cfg from current AC1900 to newer AC1900
Hi all, Hoping someone can help with this. I think I am on the right track but just need confirmation and/or input to adjust correctly if I am not. I currently have an AC1900 R6900v2 router and ...
Jun 17, 2021Guru - Experienced User
If its the exact same model and version, you can do it.
otherwise, you shouldn't do it. Sometimes theres slight differences even between versions and using a configuration for a different device can causes problems.
Better to do a clean install.
michaelkenward
Jun 18, 2021Guru - Experienced User
And exact same model mean the same V version.
Better to do "alt + printscreen" grabs and then to transfer the details manually.
