MrEugeneKrabs's avatar
Oct 19, 2015
Transfer speed
I have a Nighthawk R7000 router. To the usb 3.0 and the usb 2.0 port I connected a WD Elements 3.0 usb hdd and a WD Passport 2.0 usb hdd. It worked flawless.   While experimenting I discovered that...
  • mondenath's avatar
    Oct 19, 2015
    Yes when you connect a usb 2.0 hub it will downgrade.
    The rated or idle transfer speed of R7000 is below
    USB 2.0 Read 35MB/s  Write 28Mb/s
    Usb 3.0 Read 70MB/s  Write 35Mb/s
    These speeds are when devices connected to LAN port and read and write to usb 2.0/3.0
    The wireless speed will vary based on 2x2 or 3x3 or 1x1 clients n or ac. Even at Idle the speed will match to LAN connected if you get the Maximum Link rate.
