tdkehoe's avatar
tdkehoe
Transmit Power Control (TPC)?
I updated my R6700v3 to Firmware Version V1.0.4.128_10.0.104. The Transmit Power Control (TPC) is gone from the Basic > Wireless control panel. TPC is why I bought the R6700v3. Is there another router I can buy that has TPC? Is TPC gone forever from the R6700v3?
1 Reply
  • FURRYe38's avatar
    IF it's not seen under Basic tab or Advanced Tab/Wireless settings, then you can either downgrade to what had that feature enabled or find a different newer router. Most RAX, and Orbi series systems have transmit power controls.
    Is there a problem that your having that you need transmit controls?
