jayman9207
Feb 06, 2016Guide
Tried Smart Connect Option - Now 2.4GHz Devices Won't Connect
I enabled the new Smart Connect feature on my R7000 and nothing would connect and get an IP address to either . I turned it off and reset my wireless settings to what they were before the change and...
- Feb 07, 2016
Factory-reset and manually set-up fixed all of my problems. Even the 'Arlo' ghost went away.
storm1985
Feb 06, 2016Prodigy
If you dont need the new features of the latest fw, I suggest you dowgrade it to fw v1.0.4.30
Highterm
Feb 07, 2016Aspirant
I seem to have the same problem since yesterday (6th Feb) after updating the router firmware.
I tried returning to the previous firmware but still have the problem.
