Dogbark
Mar 31, 2021Follower
Trouble Setting up my Nighthawk ot run 500 Mbps
I just was upgraded to 500Mbps and all I can get is 250Mbps on my Nighthawk. The documentation for the Nighthawk says it can reach download speeds of 2300Mbps so I thoght I was good to go. The serc...
Apr 01, 2021Guru - Experienced User
what actual router do you have? (hint ac2300 is a speed and nighthawk is a brand)
What firmware is on it?
What modem/gateway is it connected to?
How are you testing speeds? Wired? wireless?
