lrsmith1957
Nov 20, 2022Aspirant
Trouble shooting - Nighthawk R7690P Firmware v1.4.4.94 not broadcasting 5G signals
My Nighthawk R7690P has been working fine for years now but I've recently noticed the 5G options have disappeared from the options in the network options on all my devices. That includes my laptop, m...
- Nov 21, 2022
Have you logged into to check if smart connect is enabled?
Smart connect combines the 2.4ghz/5ghz channels into one ssid so they don't show up as separate.
lrsmith1957
Nov 22, 2022Aspirant
Thank you, that was it. I'm guessing the last firmware update automatically turned that on.
Nov 22, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
